I have lived off grid for 20 year. My first solar system was a 22w panel that ran 1 light and a radio. The second was 100 watt that ran several lights and one fan. Now i have a .5k 12 volt system that runs my whole house. Fans, computers, lights. I put each one up.
Now i want a swamp cooler. it is hot in the CO high desert. I have 8 250v 24w panels and 6 12v lead acid 104ah batteries wired series/parallel for 24 v.. Both of which i got at a huge discount due to being used. The batterys are a year old and have been checked and charged by professionals.
I ran 1/0wire from the panels to the shed, it was 60' underground in conduit. I have the first set of 4 panels up and wired to 24v but i think i am going to have to rewire to 46 v so that the next 4 panels can run on the same wire. I bought a 40a mppt chg controller for the first 4 panels and planned to parrallel it with the second set of 4 but now realize that the wire is too small and i am NOT going to run another line. So will change to 46v panels and 60a?chg controller?.
I have hooked the first 4 up with a combiner box/breaker box. to mppt chg controller just to get the batterys back to full as it has been 2 weeks. This weekend i will set up the fuses, disconnects, indoor plugs for indoor dc 12v lines and start to add the lines for the 2000 watt inverter that i will buy next.
I plan to use a 60a fuse between mppt chg controller on #6 wire 2" long. I need to know if all this is ok the way i have it planned or if i need to change anything before I do it.
