Hello, because of the lockdown I find more time to mess about it the solar shed. I have a Victron Battery Protect in between my bank of lead acid's and my inverter. I programmed the Victron to programme 4A which if I understand the instructions, means it will switch off power to the inverter if the voltage falls bellow 11.5v for 90 seconds on a 12v system. Can someone confirm that is correct ?
Am I correct in thinking that if my (old) batteries cannot sustain 11.5v for 90 seconds, then the Victron will allow the batteries to drain to 10.5v, at which point the inverter BP will kick in, sound an alarm and cut the power ?
Thanks
Ump..
Edit - here is a link to the instruction.
Thanks
Ump..
