Hello, I am new here and to Solar wondering if anyone can guide me in the right direction to set up a 12V solar system my problem is
I have 4 x 250W solar panels that are rated at
Maximum peak voltage (VMP) 18.7V
Open circuit voltage (VOC) 23.37V
Max peak current (IMP) 13.37A
Short circuit current (ISC) 14.85A
I have a 60A PWM regulator/controller That is rated for PV input of 730W at 12V / 80V max input
I am thinking of getting another same 60A PWM regulator/controller and run 2 panels parallel on each regulator/controller?
Is this setup likely to over/undercharge my Batteries?
would having 2 controllers provide too many amps?
Battery specs
Bulk Charge Initial Charging Current less than 30A
Voltage 14.5V @ 25C/77F
Temp. Coefficient -30mV/C
Float Charge No limit on Initial Charging Current
Voltage 13.5V @ 25C/77F
Temp. Coefficient -20mV/C
I would be connecting the regulators /controllers to a battery bank consisting of 3 x 140AH AGM batteries connected parallel giving 420AH that will run a 1000W 12V/240AC inverter that will have usually have 300W or less like 150W max load.
Also, the Batteries have already been charged to full capacity with an AC charger.
Thank you
Battery specs
Thank you
