Hi guys
need a little help with a basic setup I'm trying to get running.
The setup will be running a small 20w irrigation pump ideally I'd like it to be running constant 24hr
195w mono panel
110ah leisure battery
20amp charge controller
Pump runs fine off the controller load outlet with just the battery connected
but soon as the solar is connected to controller the pump stops
What am I doing wrong
There is a 5amp fuse on the pump side
and 20amp on battery
Could the settings on the charge controller need changing?
any help would be great Thankyou
195w mono panel
