Okay, so I am looking to get opinions both good and bad on a potential upgrade to my family cabins solar system. Just a little back ground had a small 12v system for years. TBH, we had very limited knowledge on solar capabilities and kind of patched a system together that worked for us. Fast forward a couple cabin extensions later and we have needs that outweigh our capacity. Our mistakes
Announcement
No announcement yet.
Off Grid Cabin Solar Upgrades - Time for a system that actually works. Please help!
Hmm for some reason I cannot post my full question - I attached a document maybe someone could give it a read and post some comments? Much appreciated Thanks guy SOLAR QUESTION.docx -
I give up. I tried editing out apostrophes, hyphens, and it still chokes on some characters. This forum is not one you can copy and paste into, sorry about that.Comment
Good to know. I'm new and tried copying and pasting. Maybe I'll re type it in tomorrow I'm done with the hassle for today lol. Otherwise should be able to read it on the word doc! Thanks thoughComment
The first thing I would do is SELL the inverter. Your 2812 is a good inverter and you should be able to find a buyer for it without too much trouble. Craigslist comes to mind here. Save yourself about $300.00 by buying a Midnite Solar Classic 200 SL charge controller. Make up the difference and get a higher voltage inverter.
You will need to do something about your battery bank. Normally it's not recommended to add new to old batteries. What is the status of your batteries? If it were me I'd consider adding two more of the same batteries so you can achieve a 24, or 48 volt bank.
You are on the right track thinking about using a high voltage controller and moving your array to the sunny roof. The key to doing this is to get your voltage as high as you can safely input into your controller. The cold temperatures in your local would require diligent calculations of the temp. coefficients of your panels so as not to over volt your controller. The Midnight controllers have a feature that's called HyperVoc. If you went to a 48 volt battery system you can safely have a Voc. of up to 248 volts. I'd try to stay away from that limit but this feature can be a controller saver in the event of a super cold situation.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
My experience with the PT100 is that its a good unit, easy to install, and no bugs using pretty basic setups.
You can assume arrays will produce 70-80% of nameplate wattage, and you should account for that loss when setting up an array
100A @ 15V is going to need 1500w delivered, and array must have 1875 w to reliably give you your 100A
Or maybe is it time to look at a 24 or 48V system, price out costs each way.
Originally posted by littleharbor View PostThe first thing I would do is SELL the inverter. Your 2812 is a good inverter and you should be able to find a buyer for it without too much trouble. Craigslist comes to mind here. Save yourself about $300.00 by buying a Midnite Solar Classic 200 SL charge controller. Make up the difference and get a higher voltage inverter.
We have USL16s - they are about two years old. So adding two more at this point is an option we are looking at. Obviously not ideal - but I think if we went down the route to bite the bullet and increase our voltage, the battery mistmatch would be a small cost to the benefit of increasing.Comment
Here's the commonly referred to battery wiring page from Smart Gauge, Method 3 is the buss bar style
http://www.smartgauge.co.uk/batt_con.htmlLast edited by littleharbor; 01-11-2019, 12:20 PM.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Originally posted by mcinmylo View PostGood to know. I'm new and tried copying and pasting. Maybe I'll re type it in tomorrow I'm done with the hassle for today lol. Otherwise should be able to read it on the word doc! Thanks though
If the source is a web page, word processing document, or PDF, what you copy may be more than just the visible text and may contain formatting characters as well.
Those will cause unpredictable screwups in what ends up on the Forum.
You can generally get around this in one of two ways:
1. Compose your text in a text editor that uses simple unformatted text only (like Microsoft Notepad in ASCII mode) or
2. Paste the copied text into a simple text editor, delete the formatting characters and strings, then copy the text that is left and paste it into you Post.
The other limitation is that text containing tabs and white space composed of multiple spaces may look very different on the Forum page. This particularly applies to tables of columns or ASCII artwork, you may have to embed that text block inside a CODE tag. (The "#" button on the formatting tools bar. If you do not see it, click the underlined A button to show the format bar.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
