What is typical array voltage? I keep reading how series in the proper way to set panels up, If you have 4KW of panels (12-14 individual of 30V+) that means the whole array must be 400+V while CC can only handle around 200 volts max. Do they split the array up into two groups paralleled or something?
If battery bank is far larger than array but array voltage is alot higher than Batt bank, like array 60Vmp vs 24V bank. will the battery still pull down the array voltage so it won't charge?
Can equalization be done with CC and solar over a period of a few days provided you are not using the bank with any loads?
thanks
thanks
