I was recently gifted 5 15w, amorphous 12v modules. I think they were bought with a harbor freight kit a few years ago. Assuming 70% efficiency from the modules, I can generate ~50w at 12v. What would you do with 50w of free panels??? I'm looking for ideas. Are they even worth messing with? I was thinking about using them to run a fan in the my shop (only during daylight of course). Do they make DC fans or will I need an inverter? It seems silly getting an inverter for 50w...
What would you build?
Probably the best item that came with those HF panels were the DC lamps. IMO a couple of very low wattage LED DC lamps would be the limit I would expect to work with those panels.
You can find a number of DC fans that work well with solar panels. I actually have a 12 inch roof vent fan and a 10 watt panel that works just fine together. -
Those Harbor Freight panels don't last more than a couple years in continuous use.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Well with five of those panels to use as frames would make a nice box or trash bin. I hope they came with the factory cardboard box because they are worth more than the panels.MSEE, PEComment
Good thing they were free right?
I put the multimeter on them and it looks like I'm getting about 1A (21w @ 22v) off of them. I could charge a cell phone, but I need to lower the voltage right?Comment
That would be open circuit voltage. Under load the voltage and current will be lower. I believe those panels are rated at 15 watts2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
This is a project to teach my kid about the basics of electricity (and to brush up on it myself). So keep in mind before bashing it, this is meant to be fun/educational.Comment
It will require a battery and charge controller, or about $75 to generate 1-cent of electricity per day. Then about 2 or 3 years time to replace the battery. How is that for fun and education?MSEE, PEComment
Yeah. I think that the HF panels would be just fine for kids to learn a little something about solar. Think about all the "experiments" you did in grammar school and were they worth the cost?Comment
MSEE, PEComment
So everyone tells you the box they came in is worth more then the panels and I am the bad guy for being honest?MSEE, PEComment
