I've been running a small WalMart Haier 1.7 dorm fridge in my bus. I have a Renogy 150watt panel, Renogy 30amp charge controller, Xantrax XPower 1000 inverter with Xantrax ATS. For the leisure battery, I am running a deep cycle marine. This set up has been powering ONLY the fridge. I have been having issues with the inverter tripping for a while now. But in the past two weeks, the problem has risen to the inverter now won't turn on at all. When I turn it off and back on, the red/fault light just stays on. I can't even reset it.
Is this inverter shot and, if it is and I need to replace it, should I upgrade to an at least 1500 watt one?
Thank you for any help. If I need to provide more info, just let me know.
