I have 6 - 12volt batteries that are 105 Amp-Hour each. I would like to make a 24 volt battery bank. I would like to wire 3 pairs of batteries in series, and then parallel them before the 1500 Watt/24 Volt inverter.
Questions:
Am I right to assume this will equal 315 amp hours total at 24 volts to inverter?
The batteries have bus bar connectors to make series connection for 24 volts. What size cable would be needed for the parallel connections and the connections to the inverter?
Should the charge controller wires be hooked up to the opposite terminals of the load side of the batteries?
Thanks in advance
Questions:
Thanks in advance
