Yes, the main energy provider here in Greece supports net metering programs. Do you suggest that I should follow that path?
Newbie here, looking for advice on new system
100% efficient unlimited capacity storage system (Net metering) vs inefficient costly limited capacity and short life batteries.
Now if you goal is to save money AND have some backup then YES go net metering with a battery backup solution.
If your goal is to spend more money on power and have a lot of maintenance then go off grid battery solution.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Maybe it ought to be the most referenced and shortest post ever turned into a stickie.Comment
And I will probably keep taking advantage of it by storming you with new questions about net metering, in the near future
Seems like I am going to start research on that one then. Thanks guys, you have been really helpful and you saved me a ton of money. I appreciate your help.
BTW, welcome to the neighborhood.Comment
