Help with non-standard panel
  • Mattowens
    • Jan 2018
    • 3
    Not to hijack but I cant seem to start a new topic. I'm in a similar boat though. I got 4 240w Vmp 47.6 Imp 5.04v Voc 58.9v and 4 12v 150ah batteries. I am not sure what the actual voltage of the panels are I thought 48 but I am thinking 24 now. I would prefer 24 then I can setup the batteries as 24v @ 300ah system. Thanks and again sorry about the hijack
    You can start your own thread / Topic , by going to the proper forum level for your question
    ( try here - https://www.solarpaneltalk.com/forum and then look for off grid, grid tie, battery ... whatever
    Top left corner of the forum is a NEW TOPIC button Press it.
      It looks like you have something like Canadian Solar's CS5P-240P. That isn't considered a "battery panel", sized to support a particular voltage... it would be something like a "33 V panel" if you went by battery sizing.... safe to use on a 24 V system, but too small for 48 V unless oyu had two in series.
      In practice, to get the most out of that panel you'll need an mppt controller. If you use a PWM controller with that on a 24 V system, it would effectively turn your 240 W panel into a 120 W panel.
      (I moved this post to its own topic).
      • Mattowens
        • Jan 2018
        • 3
        Appreciate you moving this. I can't find that button. Not sure why, I looked all over.
        • Mattowens
          • Jan 2018
          • 3
          So it was most likely designed for a grid tied system initially? I will set the batteries up as 24v @ 300ah and get a mppt. Thanks so much I was struggling to find the right things to use this at my camp.
