Not to hijack but I cant seem to start a new topic. I'm in a similar boat though. I got 4 240w Vmp 47.6 Imp 5.04v Voc 58.9v and 4 12v 150ah batteries. I am not sure what the actual voltage of the panels are I thought 48 but I am thinking 24 now. I would prefer 24 then I can setup the batteries as 24v @ 300ah system. Thanks and again sorry about the hijack
Announcement
No announcement yet.
Help with non-standard panel
You can start your own thread / Topic , by going to the proper forum level for your question
( try here - https://www.solarpaneltalk.com/forum and then look for off grid, grid tie, battery ... whatever
Top left corner of the forum is a NEW TOPIC button Press it.
Originally posted by Mattowens View PostNot to hijack but I cant seem to start a new topic. I'm in a similar boat though. I got 4 240w Vmp 47.6 Imp 5.04v Voc 58.9v and 4 12v 150ah batteries. I am not sure what the actual voltage of the panels are I thought 48 but I am thinking 24 now. I would prefer 24 then I can setup the batteries as 24v @ 300ah system. Thanks and again sorry about the hijack
In practice, to get the most out of that panel you'll need an mppt controller. If you use a PWM controller with that on a 24 V system, it would effectively turn your 240 W panel into a 120 W panel.
(I moved this post to its own topic).Last edited by sensij; 01-05-2018, 08:58 PM.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
Originally posted by Mike90250 View PostYou can start your own thread / Topic , by going to the proper forum level for your question
NewTopic.jpgComment
Originally posted by sensij View Post
It looks like you have something like Canadian Solar's CS5P-240P. That isn't considered a "battery panel", sized to support a particular voltage... it would be something like a "33 V panel" if you went by battery sizing.... safe to use on a 24 V system, but too small for 48 V unless oyu had two in series.
