It's been a while since I've been here and need some good advice. I have an off grid cabin in the mid-central UP of Michigan. We use very little power, but do have several 10W 12v LED lights that we use during the hot summer months instead the heat generating gas lights. At night we run a 110v small table top fan. We have a 110V cell signal booster that we use a few minutes each day and that's about it. My current set up is 4 Renogy 100w panels with a commander 30A MPPT controller and two North Star 200aH batteries. The 12v LEDs are run off the load side of the controller and the 110v stuff is powered by a 3000W sine wave inverter rated for 30A. Mostly we are there from Friday evening to Sunday evening, but twice a year we spend about 10 consecutive days there. The system works well for me, but I came across a deal that was too good to pass up.
I was able to purchase 36 sealed AGM 83aH batteries that were in a UPS system that I take care of. I know for a fact that the system has been maintained and that these batteries have only been discharged once in the 5 years since they were installed. Manufacturer says they are rated for up to 300 complete discharge cycles. All voltages and resistance readings were perfect so for $200 I couldn't resist. Now that you know about my screamin' deal I'd like to upgrade my whole system to allow me to convert to a 110V well pump. The current pump is a 1/2hp 240V pump that requires me to run the generator meaning I have to go out to the well shed and manually start the genny. Not horrible, but it can be a pain especially when it's raining. I would like to replace the pump with a 110v 3/4 hp with a 120' of lift and run it off of my solar array.
My question is, should I use all 36 batteries? Since my power usage is very limited even with the well pump, which even with showering only runs 4-5 times in a 24 hour period: is 36 overkill? If not, do I need a monster solar array or can I get away with say 1200-1500W array? Winter visits are far and few between so the 2-3 hours average daylight shouldn't be a factor since the visits during winter could be 3-4 weeks between. Summer is closer to 4-5 hours of sun/day and about 5 days between stays. Should I go 24V or 48V? I'm leaning towards 24V. What inverter and controller would you recommend? What do you experts think?
