Hello everyone!
I'm going to be installing a 1,240w system on my 38' fifth wheel with residential fridge and I'm tired of lugging around (2) 3,500w Champion generators and running them in parallel. I'm installing soft start's on both AC units and expect I should have no issue running everything on one generator, possibly even going down to a Honda EU2000. The system details I've decided thus far are:
(4) 310w panels in 2 parallel strings
Midnite Classic 150 charge controller
Magnum MSH3012M 3000 Watt 12V 125A Inverter/Charger
Corresponding displays, shunt, BMK etc.
Currently the RV has (4) 6 volt golf cart batteries, I'm considering swapping to 3-4 lithium batteries but for sake of simplicity lets not cover that aspect now
I've opted to do 2 parallel strings rather than 4 panels in series due to voltage limitations with the Classic 150 controller. That said I'm trying to correctly size wire gauge from the roof to the charge controller. My general calculations show the panels have a max amperage of 8.53 at 36.3 volts, which if I'm correct should render 17.06 amps at 36.3 volts when configured as stated. Correct?
Regardless of the exact amperage/voltage (if I got that info incorrect) I believe 8 gauge wiring from the roof to the charge controller should suffice, I don't have an exact measurement but I'd think under 50 feet is realistic, obviously do my best to keep the run as short as possible. Am I correct thus far?
If I'm correct in the previous assumption, my next question comes down to the parallel connection, the easiest route seems to be branch connectors as I've used in the past on a pair of Renogy 100w panels. But on a system of this size should I be using a combiner box? I can if need be, I'm just trying to keep things simple and weather safe as it will clearly be exposed to the elements (unless I were to send 4 wires through the roof and do the combiner behind a cabinet or something to that effect).
And now, regardless of that setup, I need to throw in a breaker near the charge controller, what amperage breaker should I be using? I notice the panel cut sheet listing the same as most 24v panels I've seen at a max of 15 amps, but with two panels in series and then paralleled I'm expecting hitting a max amperage of 17.06 (which I'll clearly never actually see with panels flat mounted on an RV but regardless the theoretical amperage exists). This would tell me I need a breaker in the 20 amp range, but that is beyond the 15 amp max listed by the panels.
I appreciate you taking the time to read this! I've attached 2 screenshots, one of the panel information (again I'll be using the 310w variant), and a screenshot of the Midnite solar sizing calculator with the panel specs input and well within the limits of the Classic 150 controller.
