Good Day All,
Been working out he calculations for my RV solar and would like input, validation, corrections, improvements if you don't mind.
I travel my RV 9 months a year and am in one place for longer than a week.
Currently have 4 Trojan T105 batteries -- 440Ah
Wish list for Solar is:
Renogy Poly 320w 24v panels x 2 in Parallel should be 640W or 26 amps at controller
MPPT controller - Blue Sky 3024 DiL and adjust charging to batteries specs 14.82 / 15.5 / 16
Usage is as follows: 24hour in non frugal mode is 3Kwh measured by Kill A Watt meter -- amp hour drain on Batteries over 24hours 300Ah
I believe I need to recover the evening Drain of MAX 200Ah - this drain is lights, residential fridge, charges, TV DVR etc.
From what I have read here, the recovery formula is Watts x sunlight hours useable, x efficency
My calculations mean 640 x 5 x .66 = 2112 or 211Ah
I believe this will work as designed but I am open to any and all comments suggestions improvements.
Appreciate the input,
NutinElse2do aka Richard
