Is there a 'smart' MPPT controller that communicates with Inverters to adjust for load, instead of relying only on sensing battery voltage drop before going into Boost mode?
I find it annoying that my MPPT allows my battery bank to discharge even though it has more than enough power available to supply the Inverter and still recharge the battery bank, (during the day, that is).
If someone hasn't invented this by now, there's an obvious niche that needs filling. At the very least, maybe an 'amp sensor' you can attach to the Inverter input cable that reads amps just like the ones that already exists for hand held meters like electricians use.
