I'm finishing off a solar project for our pop up camper. I have a total of 12 100 Watt Renogy 20 volt poly solar panels and I have them running into a Midnite Solar Classic 150. I currently have it set up with two quick disconnect feeds of 10 gauge cable with 30 amp inline fuse. I was wondering if I should run two sets of 6 panels in series that would have open voltage around 120 volts but low amps, or I can add on two more sets and have four sets of 3 panels each at 60 volts. The panels are not going on the roof, theyes are free standing so I can adjust them during the day.
Would the higher voltage runs be more dangerous with a temporary solar set up with panels laying on the ground (propped up with legs to give it the proper angle).
