I'm gathering up the components for a solar setup. What I have purchased so far. (all still in boxes) Xantrex SW2000 2000w inverter (1.8k continuous / 3k surge) 6 - 100w mono panels = 600w total, 4 - 6v vmax xtreme 235ah batteries = 12v 470ah (If I keep to 25% discharge) 117.5ah safe usable storage. Makeskyblue 150v 60a mppt controller ($150 controller could be questionable but had good reviews, open to recommendations) 2/0 wire cables for connecting together the battery bank and running to the inverter. This will be installed in a diy campervan, so no super long wire stretches and that brings my first questions. Van is old fixer upper dodge b350 ada hi-top, stripped out inside for the build I'm 6' tall, standing inside is no problem. Fiberglass roof space is 50" wide 13' long, plenty room for my panels. Question: what I have planned is buying 4 3Y connectors, 3 panels to y connectors & 3 panels to y connectors, combination will bring 4 cables from roof inside, 2 + & 2 - down to my controller or bring all 12 down close to the controller using y connect or connect to the controller direct? Any of these configurations would be of any concern? I do not know the loss factor using y connectors, I see their rated 20-30amps, the panels I'm using, labels rate 5.5amps each, doing math, would be close to 36amps but factoring in loss, It's not going to be that much? I would have room to run cables as many cables the most efficient way, I know you never go wrong with the biggest wire the shortest distance. Most mc4 length / run of cables is 10-25ft, most prefab cables are 10 awg, see a few 8 awg, go with prefab 8 awg cable or something else? my longest cable run to furthest panel shouldn't be over 25ft, panels nearest to the battery bank should be closer to 10ft. I live in Florida, a small window a/c would be on my wish list. During peak sunlight hours, would my planned setup keep up (or close) with a energy star 5,000btu window a/c? All feedback welcome, the good, bad or ugly. I have $2k invested in solar components, I do not want to damage $1k battery bank, any advice to modify, help preserve or improve will be very much appreciated. Thank you for your time and for this wonderful forum.
Advice Needed - Solar Setup - DIY Campervan
With a 150 voc. max of your controller you can safely series wire 3 panels, series wire the other 3 panels known as 3S/2P and combine those two strings. Then bring the combined output into your controller. Any more than 2 paralleled panels or strings of panels will need to have over current protection ( fuses or circuit breakers). The beauty of an MPPT controller is that you keep the wiring simple and less costly over a PWM controller.2.2kw Suntech mono, Classic 200, NEW Trace SW4024 -
Thank you littleharbor, would running 2 - 150v Controllers to the same bank work more efficiently? 3 panels wired to 1 controller, 3 panels wired to controller #2, both controllers feeding the 4 - 6v / 12v bank?Comment
Why would you want 2 controllers when your one 60 amp controller will handle all your panels?2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
I didn't know, sounded like in the reply, running more than 3 panels would equal more than 150v rated for the controller.Last edited by rick2106; 10-21-2017, 03:12 PM.Comment
I suggested going 3 in series plus the other 3 in series, then parallel the two strings. which will keep the voltage in a comfortable range. You have 600 watts of solar your 60 amp controller should take up to 720 watts before maxing out.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Got it, first time around, I did a quick read on my little cell screen and I misunderstood.
Thank you again, I need all the help I can get
One step closer, I will order 2 sets of 3Y connectors.
I'll get better measurements today on how long my 2 parallel strings running to the controller.
8-awg would be recommended on my 2 strings of cables running into the van?
