I've been doing research and reading the forums heavily... Really enjoy your posts.... but this one is confusing..
In this thread:
You make the following statements:
The way I'm reading this is you're suggesting that one must use up all the available power from their solar panels to charger their batteries.. That "you are going to fry your batteries with 160 amps".. Couldn't one just dial down the output of the charge controllers to match the battery bank size?
Or is your statement directed at a situation where someone is trying to harvest every watt of power from every component and assume that all things will be run at their maximum levels?
I don't see a problem with having an oversized PV array, and oversized inverter attached to an undersized bank of batteries so long as the loads (and any generator support) is managed correctly.. As a newbie to this, I read your statement as saying "you must charge your batteries with all the power your pv array or generator creates"
Did I get that right?
Thanks,
In this thread:
Thanks,
