Setup, Would there be an imbalance with this setup?
you picked very challenging project for learning: as your temp can go to -30 you need to ensure your batteries are fully charged otherwise their electrolyte becomes just water and readily freezes tearing apart their cases. With -30 I'm not sure electrolyte itself won't do it either, I forgot the freezing point temps for different SOC. On top of that batteries perform poorly at those temperatures as they're still based on chem reaction and that strongly depends on temp.Comment
image_8662.jpg Here's the battery freeze pointsPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
you picked very challenging project for learning: as your temp can go to -30 you need to ensure your batteries are fully charged otherwise their electrolyte becomes just water and readily freezes tearing apart their cases. With -30 I'm not sure electrolyte itself won't do it either, I forgot the freezing point temps for different SOC. On top of that batteries perform poorly at those temperatures as they're still based on chem reaction and that strongly depends on temp.Last edited by Aspire; 08-04-2017, 01:29 AM.Comment
The thing is, the battery's are made for cold weather, but yes, lead acids do preform really poorly in the winter. lucky, no usage will be seen in the winter, and even if they do, it will only be once. These battery's are made with Calcium-lead alloy instead of pure lead. (not sure what you would think about that.)
Mike conveniently posted table above showing among other things you won't be able to discharge your battery below 75% in the winter time to remain in safe territory from freezing point of view leaving you with only 25% available capacity.Last edited by max2k; 08-04-2017, 12:49 PM.Comment
sensij this setup isnt purely for making a house run, its just to power a shed for free. The 20 watt panels are from 2 - 72watt kits, which i bought on the cheap from my work. what would be the problem with the batterys?, or does the application clear that up? Also, the panels are rated for 18watts, but ive seen them produce 20 watts.
MSEE, PEComment
Sunking well, that i knew. But i have only spent around 500$ for all of this anyways, so meh. this is just hobby nonsense, with, well, a bit of sense thrown in so i can actually learn something. if i wanted to power the house, i would spend the 10k + (probably around 20K actually) to do it.Comment
max2k well, ill just pull them inside during the worst of the winter then.Comment
max2k well, ill just pull them inside during the worst of the winter then.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
he'd need heater and some automatic 'watcher' to keep an eye on that- -30C is no joke and it usually comes in the middle of the night or what is worse-early morning. It takes single 'accident' to render his batteries junk.Comment
That's why I was seconding the keep them inside but with a battery box.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
