Want to start of by saying hi to everyone as I'm a greenhorn and this is my first post.
From what I've been reading and studying he's last 2 weeks solar can get complicated with all different parameters to consider. Every hour I read I learn something new that actual contridicts my previous thinking. My father in law and me are installing solar at our Northern Ontario camp that currently is being powered my AC and a 2000 watt Honda suitcase genny. All of our appliances (hot water, stove, fridge, freezer) all run off Propane so no big loads.
Here is what we would run off solar and all specs of what we would need and use it for
Led lighting 3w
Satellite 30w
Lcd TV 110w
DVD player 35w
Small Table fan 15w
At one time we will not be more then 180w with usage around 700-900w for the day. In the no snow months we usually get up to camp around noon-2pm on a fri and stay till noon on a Sunday so rely only using power the Friday night and Saturday cause Sunday is wake up and pack to come home. Maybe twice a summer we might stay 4-5 days but can suppliment power if needed with the 2000w Genny
So I will list " what we have" and what we will be needing cause don't want to buy stuff that is not needed
1: Already have Sunforce 2500w Pure Sine Inverter with remote on/off (my father in law jumped the gun last year buying it before he knew what was needed) I know it's way overkill so is it suggested to sell and get a smaller one and what benefits for our situation would we see with a smaller 400-600w inverter?
2: Already have (four) TCR-235 6V 235AH 478RC/25A DEEP CYCLE Batteries (BIG 6)
We were originally thinking 2s2p for 12v 470ah but if we did need a smaller inverter should we do 24v 235ah or stay 12v higher ah?
3: Already have (four) 100w Sunforce crystalline 5.8a 17.1v working volts which I presume is max power and 21.4v would be open circuit? (Stats on panels only say 17.1 working volts and don't say short circuit volts)
Solar chart show 2.0-2.9 hours sunlight/day on worst days of year which we would be at camp anyways
Should we set up all 4 in series for higher Volts or 2s2p????
4: it's 35 feet from our panel arrays to the spot where the controller and batteries are and 12 feet from there to the AC breaker panel
5: on days that there isn't any sun or say winter time how should we wire in our Suitcase Honda 2000w genny to run camp and not damage anything? If we needed to run the genny to charge the batteries can it also be running power in the camp at the same time?
So that's what we have and still need cable, MPPT Controller and whatever else such as a junction box and breakers
So with the low demands we need and the panels, batteries and inverter we have what do you suggest we get for MPPT controller, cable gauges from panels to controller, controller to batteries, battery to battery and battery to inverters, and how should we set up panels?
6: what MPPT controller would we need
7: what sizes wires do we need
8: do we need breakers between panel and controller
SUNKING I wanted to send this in a message to you but can't find out how. I see you really know your stuff
Led lighting 3w
Satellite 30w
Lcd TV 110w
DVD player 35w
Small Table fan 15w
