View Post
MPPT Charge controllers and Panel Connections
Originally posted by Simo View Post
Thanks for your constructive criticism FOOL. Over 20,000 post with not much content.....
I felt the same way when I came to this forum and got put off from some real up front and frank language. I did not listen and ended up spending well over $2500 on a solar battery system which will deliver maybe 600Wh a day which is pretty pitiful.
Try not to be put off by what some people say and hopefully you won't make the same mistake I made and others after me.Comment
Originally posted by SunEagle View PostWow. My guess is that system cost at least $75k and those batteries will be a money pit for years to come. I guess the OP can justify that type of expense to live off grid but if it was my money I would find another way to get power to my home.
MSEE, PEComment
Originally posted by Simo View PostWhere do you get your pricing from....... door to door battery sales?
Solar Troll.
Batteries can be found at all prices from many different sources. But if you are looking for quality batteries you need to go to a company that makes them and not some 3rd party website. You never know what you will really get going that route.Comment
You will be lucky top get 2 years service out of them. In my book that makes you a damn fool using batteries that are not made to do what you want. You are buying a battery made for Telecom, not daily deep cycle applications.
If I had to guess you are a big enough fool to buy them used from a Telecom Second Hand Surplus. Let me tell you how that works because I use to do it. After 10 years of Float Service, telecom have to pay big bucks to dispose of them and held responsible for them via the Employment Prevention Agency. So we got smart and turned a huge liability into small change asset. We find a sucker, I mean some one to pay us scrap price for them and sign the paper work taking the 6000 pound monkey off our backs.
Either that or you are buying the Chi-Com counterfeits called Taico for $400 per unit from the Chi-Com Ebay Alibaba. If that is what you are getting, I pitty the fool who owns them. You are about to make the biggest mistake in your life.
So which one are you buying? The second hand used Victron, or Chi-Com counterfeits?
Bottom line here is quality batteries cost $150 to $200 per Kwh of storage for a 5 year battery. 48 volt 1500 AH battery has 72 Kwh of capacity. Simple 5th grade math. Telecom Station Batteries made for Float Service like the ones you are buying cost $300 to $500 per Kwh and not what you want. They are not made for Cycle Service. They are made for Float Service.
So you have two choices:
Listen and learn the easy cheap way.
or
You can learn the hard way by loosing a lot of money.
For you I recommend the hard way. Loose your money. But I wil give you one tip. Look for a Rolls S1860 a 2-volt 1485 AH battery.Last edited by Sunking; 04-23-2017, 11:58 AM.MSEE, PEComment
Originally posted by SunEagle View Post... I did not listen and ended up spending well over $2500 on a solar battery system which will deliver maybe 600kWh a day which is pretty pitiful.
SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Originally posted by Sunking View Post
....For you I recommend the hard way. Loose your money. But I wil give you one tip. Look for a Rolls S1860 a 2-volt 1485 AH battery.
WWW
Originally posted by Simo View PostLooking at running a rural homestead on standalone solar.
15kw panels
2 x 8kva inverters
24 x 2v 1500ah OPzV batteries.
Originally posted by Wy_White_Wolf View Post15Kw of PV into a 72Kwh battery bank tells me he's trying to overcompensate an undersized battery bank. He'll be lucky to get even 3 years out of the Rolls S1860.Last edited by Sunking; 04-24-2017, 05:32 PM.MSEE, PEComment
Originally posted by jflorey2 View PostOK. Going purely from the solar power you will need a 2400-4000ah battery (greater than C/13, less than C/8.) So to get a good battery system, like a Rolls 2YS31P system (24 x 2 volt, 2430 amp hours) you'll be spending around $25,400. How long they last will depend on how hard you push them. Using 40% of their capacity a day you might get 5 years.
MSEE, PEComment
Good catch, did not catch the panel power. Let the idiot burn his money up. Will teach him a great lesson he will never forget and may never recover from. He is down under with no access to quality batteries. Rolls would cost him a fortune.Comment
Can you explain why this battery sizing causes problems for my install. By my calculations 1200ah is more than enough for my requirements. I have upsized the panel capacity to cope with bad weather etc.
2x 8kva inverters are to cope with short high load requirements only.Comment
Thanks for the info.
You say you sized then to meet your demands. I think not because if you had used 5 day reserve capacity, you would fall between C/8 and C/12. Ideally you want C/10 charge current and that would be a 3100 AH battery.MSEE, PEComment
