MPPT Charge controllers and Panel Connections
Thanks for the info.
Can you explain why this battery sizing causes problems for my install. By my calculations 1200ah is more than enough for my requirements. I have upsized the panel capacity to cope with bad weather etc.
2x 8kva inverters are to cope with short high load requirements only.
So how did you calculate the 1200Ah? Is that what you calculated you need? How did you calculate for the 1500Ah battery bank?
If your daily need is 1200Ah you need a 6000Ah battery bank as you should not use more than 20% of it daily. That also gives you 2.5 days autonomy before reaching the 50% limit that you should avoid going below.
WWWComment
