Hi all,
I've lived off grid for about 5 1/2 years and our lead acid battery bank seems to be failing. We have a 24 volt system consisting of 12 2-volt LA batteries in a single string installed by a local solar company. It's our first experience with off grid solar electric systems and of course the learning curve has been and continues to be steep.
Here's the mystery I'd love to get some some feedback on: while troubleshooting our system it became clear that there is a consistent 10 amp draw on the battery bank even when the main panel is shut off. You would think when you "throw the mains" the amps will be 0 (at night) or more (during the day) as the batteries receive input from sun. But even shutting down the main AC panel, the PV input to the charge controllers, and the inverters (at the mate), there is STILL this mystery draw. Of course when these things are on there is more than 10 amps drawing down as the batteries meet the demands of our house load.
In addition to the steps above we also experimented with turning off the inverter circuit breakers, the inverters themselves, and the charge controllers. Even with all these turned off the trimetric shows the 10 amp draw. Originally our solar tech thought the trimetric was not calibrated correctly, but we've replaced that and it still shows the 10 amp draw.
The solar professional who installed the system is coming back to investigate further, but I also would like to hear feedback from this community since it seems to be such an unusual problem.
Many thanks for any ideas you might have, and apologies if I've left out key info.
