We have a sporting clay range that uses 12 volt batteries for the clay target throwers. During the winter they are used once a week, they are unhooked and carried to remote launchers over several acres of property, when finished they will be left on the controller for the rest of the week. They are a variety of types, amp hours etc. but should sit in the 75 to 100 amp hour range deep cycle. Not sure if there are any AGM but probably will be in the future. During the summer they may be used a couple of times a week but of course the days will be longer with more charging time.
We do not need to make them into one battery bank and there will be no load on them while sitting and charging.
A cheap 25 watt panel keeps one battery topped up on the busiest machine with no problems.
Rather than putting multiple batteries on one controller and having all the issues that go along with that, is there any reason not to put multiple controllers on a larger panel or set of panels with one battery on each controller. The plan would be to connect say 4 on/off switches in parallel to each panel (or multiple panels in series/parallel ?), and run one controller off each switch. This would allow the controllers to be switched off when not in use, then a battery could be connected and the controller switched on.
Any thoughts on the best configuration of charging multiple 12v batteries in different states of discharge, with different specs for the batteries.
So the items I am looking at right now are as follows,
Two panels $185.99 CAD Free shipping each
https://www.amazon.ca/gp/product/B009Z6CW7O/ref=ox_sc_act_title_1?smid=A3S4P673KUAQ8Y&psc=1
Two comptrollers would probably be something like 75.82 CAD free shipping each
https://www.amazon.ca/MISOL-regulator-batteries-Controller-controller/dp/B00A4AVD70/ref=pd_rhf_dp_p_img_2?_encoding=UTF8&psc=1&refRID= 4SY3YZZPGHB5J08SSAKC
Quick connects
https://www.amazon.ca/Battery-Connec...2BConnect&th=1
Mounting brackets
https://www.amazon.ca/Sun-YOBA-Solar...ting+Z+Bracket
I'm not to concerned about the efficiency as such. The two hundred watts will provide a trickle charge that will slowly build up over a few days as the batteries top off.
Shed ventilation for the charging batteries.
https://www.homehardware.ca/en/rec/i...inm/R-I2670568
Quick connects
Mounting brackets
