I have a small off-grid system and want to increase the feed-in to the batteries to use same-day when it's cloudy by upping the PV count. Doing that may generate too many amps for the current MPPT to pass through on sunny days, but I get enough power on those occasions.
The existing two solar panels are wired in parallel - if I add two more (similar wattage but different manufacturer):
1) Should I keep them all in parallel or go in series
2) When comparing the output of the old and new panels, do I use the voltage open circuit or VOC and short circuit current or ISC?
Current PV's: 235W Rated: 29.85v and 7.84amps and ISC: 37.11V and 8.58 amps
MPPT Charge Controller: 40A 12v/24v Tracer4215BN
Batteries: 4 x 110 amp
I will change the MPPT later in the year and upgrade the batteries when they are on the way out.
Thanks for your help on this.
