Hi, I'm having trouble getting a straight answer on this, and most of the online info assumes large systems with inverters, so...
I have an LTE internet hotspot that I have to relocate to the top of a hill in order to get decent reception. The hotspot itself draws about 3w and takes 12v. To beam the signal back to the house, I'm planning to use a pair of Ubiquity Nanobeam M5s, one of which needs to be on top of the hill, of course. It draws 6w and takes power via POE at 24v (I have a simple POE injector that you connect 24v DC to).
So in short, 9w power draw 24/7, DC only (no inverter). I'm in BC, Canada, roughly 50th parallel. Worst case sun is about 2.5h in deep winter, and temperature can get down to -20c on rare occasions (more often it hovers around freezing during winter).
I've had quotes for solar panels ranging from 100w to 360w, batteries up to 200ah, with some people arguing 24v and others 12v, but I can't seem to find any agreement, and these solar system dealers are really striking me as a shady bunch. From my searches online, it seems 12v panels are the most common and fairly inexpensive.
So, my questions:
- What panel wattage do I actually need? From my calculations it seems 100w would be enough, but I'm getting such conflicting info that I'm not sure.
- Is 75ah of battery good enough for this?
- Is a 12v system (with a 24v DC-DC converter for the Nanobeam) acceptable, given the greater availability of 12v systems? Or am I better off with 24v (stepping down to 12v for the LTE hotspot)?
- If I go 12v, is a single 12v battery acceptable? 2x6v? or a 24v system made of 2x12v or 4x6v?
Bear in mind that the load on this system will not change. 9w DC power draw (mixed 12v and 24v), 24/7, now and forever.
So, my questions:
