Hi all,
I'm about 50% complete on setting up my solar at a small off grid cabin. Purchased as a package: 4 195w panels, 4 250amp/hr batteries, controller and inverter. Nearly everything was prewired.
My inverter is a Go Power! GPSW-1500. What has me scratching my head is the output to the service panel. The inverter has two three prong GFCIs, nothing for a hardwire. How can I make this work where the main breaker on the panel is getting power from the inverter? Panel is a pretty typical 100amp Square D (Homeline HOM2040M100PCVP).
Also a couple questions on grounding. The bus bars on the panel are bonded and tied to a grounding rod. Can the ground from the array combiner panel and also the inverter be tied into the main service bus, or is something else/additional needed?
Last, what # of wire is ideal for running from the controls to the array combiner panel? #8, #10? Sadly, these are all the things not included in the kit setup and I naturally have questions due to being a rookie.
Thanks
Thanks
