Well i'm looking for advice on how to handle our hunting cabin. Located in central Wisconsin. Only used about 20-30 days a year at the most. Current solar panels have been in use for about 30 years.
The current panels I believe are two 40w solar panels wired in parallel for a 12v system. They are ancient but still function. The "charge controller" more like charge circuit died a few years ago and we placed a cheap https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 in its place. it charges 2 12v batteries also wired in parallel. The batteries sit on the concrete slab
What we power: We power these lights for a few hours a night at most https://www.superbrightleds.com/more...witch/682/461/ And occasionally we have a 12v water pump used to fill coffee kettles (pumped up from the well). We use lanterns mostly but its nice to have the leds work
With solar advancing so much is it worth using the old panels or buying a single new one. Do i have to rewire? My wiring is basically 10 gauge wire through some in line fuses to the charge controller and to the batteries. Should I be caring for the batteries better and what is the best battery for me? An enclosure? I searched the site a bit but i'm not sure if i should be in a different spot or if there is already a thread similar to mine.
Very low use system needed to power lights and water pump. To replace current system or utilize the current system better?
Thanks for any help
Thanks for any help
