I'm sure this has been answered before, but I can't seem to find it, so sorry for the presumably repetitive post.
Mostly need to pin down grounding, and whether need to fuse and/or GFI anything, though any any any other advice is greatly appreciated.
I'm setting up a stationary, off-grid solar rig to power a pump for a small above ground pool.
I'm thinking:
My questions:
Thanks so much in advance for any advice,
Cheers,
Ben
I'm thinking:
- 1 @ 100W Panel and Controller (probably Renogy unless shouldn't?)
- 1 @ deep cycle sealed battery
- 1 @ MicroSolar 12V 1000W (Peak 2000W) Pure Sine Wave Inverter
- 1 @ 3-Rod grounding kit (???????)
- Powering: Intex 120V Krystal Clear Saltwater System CG-28669 (and maybe some tiny things like a USB charger or small speakers) through Woods 50015 Outdoor 7-Day Heavy Duty Digital Outlet Programmable Timer
My questions:
- Need to ground panel?
- Need to ground battery?
- Need to ground inverter?
- If need to ground multiple of those, ground separately, or ground connected somehow?
- Size grounding rod needed? These ones sufficient or need full 'house sized'?
- Need to fuse? If so, at which point(s?) in the system?
- Need to GFI? If so, where/how?
Cheers,
Ben
