I have a sawmill that uses a 12 V 420 AH battery to start the motor. The mill frequently sets idle for long periods of time but I prefer not having to remove the battery and put it on a trickle charger to keep it charged. Someplace I've read that a solar panel can be connected directly to a battery without a charge controller. How does one calculate what panel to use? I would make a mount on the sunny side of the sawmill carriage and leave it there all the time. Please advise. The sunny side faces about 170 degrees south. Would I be better off using a CC? If yes, in a case like this will a PWM be a good choice, or should I still go MPPT?
If going without a CC should I size it for 1 small panel in summer, til mid fall, then 2 small panels til mid spring in parallel?
I am located on the 43th parallel in New York State.
