Hi All,
Since my last post regarding the small system I had, I have since found a much bigger use for solar in my remote aircraft hangar so have done a massive upgrade.
I purchased an EPSOLAR BN series 40A MPPT Charge Controller and am now running 10 x 100W panels (2 strings, each with 5 panels in series). I am still getting to grips with solar but so far this seems to be a worthwhile installation. It is connected, currently, to 2 x 120AH batteries (in series giving 24V system voltage).
One of the things that I have discovered is that the manuals that come with these things are absolutely rubbish. I purchased the optional MT50 remote display but the manual doesn't explain any of the items it displays. It shows you the menu structure and how to use the buttons but that's about it.
There is a real time monitoring page but I am at a loss on what a couple of things mean.
One of the screens shows the following information:
Char. Energy
Day: 0.01kwh
Mon: 0.95kwh
Total: 0.95kwh
Now I can sort of work out that the 'Day' means that in the current day the controller received 0.01kwh from the PV system (which does seem low considering this has been running for a full 24 hours now, and even though the weather is pretty grim, I would still have expected more than 0.01kwh from 1kw of panels).
I cannot work out what the 'Mon' is telling me. I can assume 'Month', but there is nothing in the manual that specifies what this is showing.
Any ideas?
Regards
Steve
Char. Energy
Day: 0.01kwh
Mon: 0.95kwh
Total: 0.95kwh
Any ideas?
Regards
Steve
