Hi Everybody. I bought an island 25 years ago and put a small panel with small CC and 60 amp battery without any knowledge just for lights and water pump on an old caravan. Then added one more small panel and battery. Children got older so tv required. I then contacted a supplier who installed 2x140 watt panels through a morningstar CC and added a 500 amp Rolls battery. Cabin was built, Grandchildren arrived, more cabins were built so added 4 Sharp 180 watt panels through a Flexmax 60 + 2 more Rolls batteries and Outback 12v inverter/charger with 2 Kw generator. Hot water, fridges and cooking is by bottled gas and heat by unlimited supply of timber. Water pumped to tanks from lake. I will be 70 on Monday and I find the task of carting gas from mainland not so easy any more so I want to use efficient fridges.
My supplier sold me 4 Sharp 235 watt panels telling me to connect them to the Flexmax 60. We installed them on the roof but at this point, before connecting them, I decided to research this subject and realised that this was wrong and that I needed an additional CC like Flexmax 80 to cope with the wattage. I also intend to add 1 more battery to balance things.
APOLOGIES FOR THE LENGHT OF THIS.
I have concerns when I read the problems encountered when setting up a master slave with the Flexmax and their interaction.
2 x 2v cells were found to be faulty and with some persuading Rolls are replacing these although they told me it was wrong to connect batteries of a different age. How else could I expand my system?
As a layman I would appreciate opinions on the above as I can't rely on my supplier.
Cheers
Cheers
