I fly less than 3 mintues consuming around around 1000-1200 from 1500ma 4s pack. I do have a charger that displays battery resistance, will pay attention next time I charge.
Thanks for the great info and your time for educating me on LiPo technology
You are welcome. Save yourself some significant battery dollars. At 3 minutes is roughly C25. Any more is just a waste of money and added weight. Gens Ace 25C are great batteries. I have a ton 3S 2200 mah 25C. Paid $11 for each.
Just looking to play around with some lifepo4 cells, dont want to spend much money so i know i will be dealing with lesser quality batts, just want to make sure they are indeed lifepo4 and not some counterfit other chemistry pretending to be lifepo4. I pump some water up from a spring at my cabin (not very often) and currently using a used car battery that is working fine to run the shurflo 12v pump, but the battery is tired (10 years old) and gets heavy on the 600' long, steep trail packing it down and back to recharge, the pump draws close to 5a for this particular lift, and i run it about 30 minutes maybe 3 or 4 times per week when i am around there. I see some cheap 26650 5500mah 3.2v supposed lifepo4 cells i can get for 3 bucks each in bulk, just wondering what pitfalls i would be looking at to run 2p4s pack for 12v 10ah which should be super light to pack and i think could do okay with a .5C draw for 20-30 mins. I have a Victron 75/15 with cable and software to set the current limit and voltages proper just not sure if there is anything to look out for with those particular batts or the 2p arrangement.
LETitROLL, here is a small pack I built using 32650 LiFePo4 5500 cells, a 4s1P pack for powering my small portable air pump. A TPU printed shell protects the pack, notice I have a balance plug just in case I want to read the voltages of each cell and balance charge the pack when needed. I also built a 4s5p pack, at 12.8V 27.5A weighing in at 8lbs is the largest I built from LiFePo4s, which I am using as a power supply from my field chargers.
Nothing stopping you from tinkering, just be safe!
I am in Burbank, Ca. It gets super hot sometimes. We have our own POCO here and they charge $0.1672 kWh at Tier2 , I am averaging around 28k per day.
Thanks for getting back to me. I just happen to know someone that lives close to me that fly's RC planes and is named Vic.
We get hot here in Fl in the summer. At least I only have to pay about $0.10/kWh up to 1000kWh and then about $0.12/kWh for anything above that first 1000.
We finally got our consumption below 40kWh a day which costs us about $4.75 or $143/mth on average (including all taxes and fees), but it has been a fight to keep other family members from leaving the lights and fans on all the time.
If you say 10 minutes says you need 6C continuous, and 12 C burst.
If you say 5 minutes means you need 12 C continuous, and 24C burst
I can do 5 minute but that would require 1/4 throttle throughout the entire flight, not much fun with that. 10 min is not possible.
Vic. You remind me of someone I know outside of this Forum. I currently live in the Clearwater area of Florida. Is that any where close to where you live?
Sunking thanks for the insights on LiPo C ratings . I don't even know how they come up with lipo rating, I only use it as reference. Maybe they label them like how the power feels... gee It feels like 50 percent better and it can hold full power 50 percent more times so I am going to label them 2x.....hmmm 40c battery is now 80C ... lol.
Anyways all my packs are the GenAce Tattu 75C, disregard the 75C, anyways all I care about is it provides the most power and hopefully withstand my punishment of 40-50 flights. Nothing like a fresh brand new LiPo cuz the next flight on it appears to be always less.
VIC unfortunately the whole C-Rating is just a crime and an arbitrary number marketers come up setting with Engineers of how much heat they think the battery can tolerate before it blows up. It revolves arounds 6 watts per AH of battery which is ridiculous amount of heat. When you stop and do some math you begin to realize it is pure BS and you are getting robbed. Allow me to you a simple question.
What is your Flight Time?
The only way you can justify 75 C is less than 48 seconds fly time. If your RC Charger can measure Internal Resistance do some experiments. Then go plug you numbers into this calculator and see what the C-Rate really is. I have measured many LiPo's and hundreds of people have done the same. No one has ever measured one more than 30C. I bet you a dollar if you used a Gens Ace 4S 1500 mah 25C battery would perform just as good as your twice as expensive 75C battery.
In order for your 1500 mah cell to be 75C the Internal Resistance would have to be .0005 Ohms. Impossible for that small of a battery. Not even 100 AH cells go that low. Most likely you will measure as low a .004 and up to .01 Ohms and find out you have 25C to 18C battery.
I try and not charge LiPo at home if I do it is inside my metal charging cabinet. Currently just flying quad racers and the packs are mostly 4s 1500mah but at 75C rating, amazing how much power you can get from them of course a 2-3 minute of flight time is really quick.
I wont hijack this thread any longer and will start a new one. I hope to get a lot of help from the experts here.
Now that is some funny stuff, I do not care who you are.
Don't get your shorts in knot, I am not making fun of you. But a 75C battery is impossible, and is pure marketing genius. You pay an extremely high premium having 75C printed on that battery. You are being ripped off.
If you want to know the True C-Rate of a RC LiPo battery, you can measure it if you have a charger that reads the individual cell Internal Resistance. If you have one you are in for a Hell of a Shock.
Here is how you do it. I will use your battery as an example.
1. 6 watts x mah / 1000 = 6 x 1500 / 1000 = 9 watts. All you are doing here is finding a thermal mass limit of your cell of 6 watts per Amp Hour of a individual cell. You have a 1.5 AH cell x 6 watts is 9 watts.
2. Now is simple Ohm's Law. Use the highest Resistance cell of your 4 cells. If your battery is in excellent shape and new will bee roughly .006 Ohms or 6 milli-ohms. Once you have that you find the maximum current your cell can safely dissipate using Ohm's Law of the Square Root of Power / Resistance. So ^2 of 9 watts / .006 Ohms = 38.7 Amps.
3. Now you find the True C-Rate for your battery and you will not be happy. C-Rate = Max Amps / mah x 1000 = 38.7 / 1500 x 1000 = 25.8C. Far from 5C you paid for..
I have only been in the hobby now for about 4 years. But after working with batteries for 40 years I knew C-Rates were complete fantasy. Every manufacture lies big time. It took me a while to find engineers that make LiPo's for RC and they gave me the Formula I just shared with you. That formula of 6 watts for every AH is ridiculous. If you were to actually run your battery at 38 amps means the battery is burning 9 watts x 4 cells = 36 watts smoking hot.
There is also a web site with a data base from users measuring Real C-Rates. No on the face of the earth has ever measured one greater than 30C. 75C is impossible. I run 25C cells and most are around 18 to 20 C. I do have some rated 45/90C Turnigh Nano's but their real C-Rate is 23 to 26 brand new.
Here is something else to consider. I bet if you measure the Internal Resistance of your cell they will be roughly .007 Ohms or 20C. 20C on a 1500 mah battery is 30 amps. That means each cell looses .3 volts per cell or 1.2 volts for a 4S pack. Again you can do the math 1.2 volts x 30 amps = 36 watts of hear cooking your battery. That is why the puff up.
Give you a hint. Buy a Gens Ace or Thunder Power 4S 1500 mah 25C battery will perform just as good as your 75C battery and only cost half as much.
I am looking into taking my pool pump off grid. This is why I am here reading and researching what I will need. I have a solar water pool heater and when running the pool pump during the day spikes up my energy bill. There are many options like a smaller pump just for the solar heater but I want to see if I can actually take the pool pump off grid. If it works out I hope to put the detached garage off grid as well, I am a night owl and the lights are always on. If it does not work out at least can take the garage lights off grid. If nothing works out at least I have tinkered.
Sounds like a fun project but while also an RC flyer I would say if you use a LiPo or FLA the numbers calculate out that the cost for each kWh you generate from a battery will still be much more (4 to 5 times) then the cost of purchasing that kWh from your POCO.
The math is easy to do to prove my point but if cost is not a factor then have fun. Just watch out charging those older LiPo's. They tend to heat up a little. Especially a 4S or bigger.
I fly 3D planes but would never buy anything from Hobby King.
There are some things I do not buy from them like servos. I have been in the hobby for 30+ years, you kinda figure out what not to buy from them. I would never buy a $10 receiver for my $2000 airplane but you know its great on a foamie.
Your probably correct that I have traded down quality from A123s. But I have to move on since A123s are getting harder to come by. I reserved the 40 pieces that I have left as receiver packs 2s1p because of the fact they are much safer to keep in my giant scale airplanes than LiPos and I can charge without removing them out of the models.
Sure these are made by Chinese Tenergy so is nearly all of my LiPo packs that fly my electric quad racers with. You have to pick and chose which one is good, my 7 year old Hobby King Zippy LiPo 20c packs are still useful today than some of my name brand LiPo packs.
I have no idea about manufacturers going out of business. I build them now does not mean they cannot be replaced later with something else. If I do my tests and they hold up for what I intend to use them for then great, I am a tinkerer anyways. I just don't understand why a single pack 3.2v 100A LiFePo4 cost $150, I can built the same rated pack with 20 cells using 32650s a lot cheaper? I guess will have to see how these Tenergy 32650s hold up.
Hello I am new here and I have just starting reading up on solar systems and wanted to tinker with it. Anyways I have been tinkering in the RC hobby for a long time and about 5-6 years ago I have been using mainly A123a and Lipo cells to power things. Lipo require extreme care however I only use them for hi powered requirements. The A123s are extremely forgiving, these were pulled from Dewalt power packs. I build 12.8v (4S10P) pack from them and replaced my SLA portable battery which typically last me 2-3 years. I do charge my A123 pack through a balance charger and in 5 years they are still going strong from day 1. Outlasting any portable batteries I have ever used.
I now have some Tenergy 32650 LFA 5500mah cells and will make 4s packs for a small off grid solar hobby (man needs another hobby) project. I have tested these cells and I can draw on average 4500ma from them down to 2.7v. I built a 4s5p pack for testing and at 12.8v 27.5A about the same size as a 12V 18A SLA battery and half the weight. However these are much cheaper than A123s, not sure how long they will last but its worth looking into. These are going for a little over $1 each and 20 cells is way cheaper than SLA that will eventually die in two years.
I am hoping these Tenergy cells will be a great alternative as solar batteries and a cheaper source for A123 cells.
What you have done is traded down from A123 to Chi-Coms that are going out of biz. Let me guess you bought them from Hobby King? You do know they are going out of biz right? I fly 3D planes but would never buy anything from Hobby King.
