I am confident I will survive just fine top balancing, thank you. If you are raising such a concern with balancing around the stage the cells are at full charge, then shouldn't there be a concern with keeping considerable distance from that point when charging on a regular basis? IMO from all the research I have done, there is little risk of destroying a cell if you manually do the cell balance at between 3.6 and 3.8 volts. Of course you don't want to forget about leaving the charger on like that fellow did and wound up destroying 2 of his cells. These cells hit 4.55 volts! No wonder they didn't survive, and yet 2 other cells did survive somehow, likely suffering from degradation?
I will have little risk in damage from going too low, as I normally don't discharge that low in the first place. I will be fine thank you, and I don't need any bottom balancing advice!
