FLA Bank size for ~700W of panels?
  • Filter
  • FLA Bank size for ~700W of panels?
    Hey guy's,
    So i'm planning a project on my shed this Spring to allow me to use it as a small shop. I plan to use some small power tools/chargers and maybe a 12A saw at some point, which is why i'd like to use a 24V bank rather than 12V. Planning on a 1500w/3000w peak Pure Sine inverter as well as a 40A MPPT controller.
    I have 2x365w LG panels coming to me shortly, which are almost brand new. I plan to wire them in series for ~70V. So that's roughly 700W of solar and 25+ amps. It's more than I originally planned, but I'd rather have more than not enough.
    Originally I was thinking use using 2 Trojan SCS225 in series (24v 130Ah)- http://www.trojanbattery.com/pdf/dat...ata_Sheets.pdf
    I think I would be fine if I was using just 1 panel, but using both will be pumping 25-28 amps into the bank which I fear might be too much. Should I be looking more into the 200Ah range now with the extra solar input?
  • #2
    The battery voltage will somewhat regulate the charge amps. When flooded batteries are quite low, they can easily absorb a lot of amps. As they charge up, they self-reduce the amps, so I would think your 2 panels will be ok. Losses, panels seldom produce their nameplate power, when they heat up, you loose 15-20% . If they are not aimed perfectly, you get less power. A fixed mount will only have 20min of good aim, after that the sun has moved. The better controllers, you can program to limit output amps too.
    • #3
      Ahhh. I wasnt sure how FLA regulated the input charge when the array is a bit oversized. I have experience with undersized solar and too low current for battery charging which I apparently is much more detrimental to the life of the batteries.
      I doubt I'll be going much past 20% d.o.d on this bank and the solar should quickly charge it back up even on slightly overcast days.
      Thanks for the input!
