Hey everyone. I noticed two things today while running an EQ and I thought I should ask around to see if it's normal or not.
48 volt 840ah battery (16-L16p)
1) It's 50 degress in my powerhouse. The batteries have been on EQ for about 2 hours now, bubbling away. When I touch the top, or sides (6 inches down from the top) of any battery, it's not that warm at all. In fact, I have never witnessed serious heat coming off these guys, even in the summer. I've read about people over-heating their batteries, so I'm curious if perhaps the cold temps up here in the mountains are helping or maybe I'm not pumping enough amps into these...
2) My Outback Inverter and Mate3 are set to EQ at 62.4 volts. However I notice that the battery is always sitting at 62.8 or 63 volts. I check voltage and SG every 30 minutes. Is this an issue at all? I've noticed the mate3 is not very accurate, in general, so perhaps it's just a cheap charger program and this is what I get...
I'm charging with a little propane genny that's putting out 14 amps at 120v AC. I did ensure that the batt was at float prior to EQ. Most SG's started at 1.25 or 1.26 (temp comp). I'm confident that with a few more hours, the SG will get to 2.77 but I'm just wondering if the above indicators might be telling me something.
Added: I should have noted that my house load is <200 watts during the EQ.
Thanks!
Thanks!
