24V working voltage range for Lithium Ion cells for a Van
Have you worked out a good way to turn off the inverter and MPPT controller remotely via the BMS? I had a quick look at the Vicron manual and it looks like it might be possible to turn the inverter off via the charger only/inverter on-off switch. I couldn't see any way to turn off the MPPT controller. As you have an electronic engineer helping, you could look at turning the MPPT controller off by modifying the temperature sensor so that BMS stops the charger by generating a battery over temperature fault.
Have you purchased a BMS from Zeva yet?
And yes, how to turn off both inverter charger and MPPT charger is something I'm not clear on. I was going to ask Victron if the communication between the inverter charger and MPPT charger that will stop charging on both.
Yeah absolutely, if we're not sure the electronics we're planning on running 24V will cope with the voltage, we'll use a DC-DC converter. Any suggestions for about 12A?Comment
Something like this ...
Buck Inverter 26 V - 32 V DC Input to Constant 24 Volt DC output 10 Amps free air (continuous) / 15 amps w/ fan (intermittent).
http://www.ebay.com/itm/DROK-Mini-El...item41b428039bLast edited by NEOH; 08-11-2017, 09:17 PM.Comment
Another thought for configuring a 7s pack. If you can take one cell out of each Ensemble 115 8p1s module to make it 7p and then buy an empty shell and one extra 5.3Ah cell to make up the extra 7p module to make 7p7s*7.
SimonOff-Grid LFP(LiFePO4) system since April 2013Comment
