Yep, that's a Gen2! Sneak it past the mrs before you run return-by date passes, and test it on your car. Like all consumer goods these days, it is wise to check. My first Gen2 7200 had to be returned as it was brain-dead. (despite having a good fuse in the clamp leads, and verified connectivity with the quick-disconnects.) Note, if that fuse IS blown, or the connection is super poor, then you won't be able to do anything but activate the power supply until the issue is fixed.)
START off with a normal charge (14.4v setting), for those fla's or if sub freezing, then cold/agm.
Here's the best part - the Gen2's seem to be a tad smarter about float - while I haven't witnessed sitting at 13.6v automatically, I DID notice that it didn't seem to just shut off like the earlier Gen1 versions did, and will do a float by offering the battery some current and allowing it to set the pace when absorb is finished (aka their "optimization" stage) - which in my case was just hovering at about 13.2v - similar to a battery tender's float. If there was a *significant* parasitic draw, then it would restart the maintenance cycle again, either that or just discharging down to the target low voltage. Of course they don't specify what level that parasitic current trigger actually is!
It drives me nuts how charger manufacturers try to spice things up with their funky descriptions that don't go into FULL detail. So there does appear to be a limited type of automatic float without you having to do anything like you would with the Gen1's. BUT, that doesn't stop you from doing so if you like!
The Gen1's specifically mentioned that the "13.6v supply" mode can be used to float large batteries, but this detail is missing in the Gen2's. Perhaps that limited type of float, hidden among the "optimization" cycle is the reason they don't mention it any more.
All the rest you mentioned sounds pretty good, except with FLA's instead of topping them off with a manually selected 13.6v "supply", perhaps it would be simpler to just let them sit on the Gen2's seemingly limited float, OR just start another normal charge cycle letting it do its thing automatically and wait another 30 days while it "optimizes"/mini-floats things in between. ha.
The gen2 simplifies things somewhat, although that means testing it within the return period to make sure it works!
You've got kind of a swiss army knife of chargers now. If those batteries do go funky, you've got the "repair" mode (similar to an EQ you do on floodies, but limited to 4 hours), manual supply/float, and now even an AGM+ mode for those batteries that can take it. In fact, I'm doing a quick test with the agm+ mode on an optima right now! I'll let you all know how that goes.
re: first let the charger do it's normal thing...
