12v to 48v
  • Svencool
    • Jul 2015
    • 77
    12v to 48v
    If I have a 12v battery bank with 4 100ah batteries in parallel now. If I put those 4 batteries in series to 48v for a total of 100ah. Lets say my load is 100 watts does my run time last longer with a 48v bank vs a 12v bank? I think there are allot more benefits to being in series than parallel for my battery bank. Also was thinking being I only have 4 100ah 12v batteries would it make more sense to make to strings of series for 24v and then parallel them in the end for 200ah? Thoughts?
    Mike
  • Naptown
    • 6880
    The battery capacity will be the same measures in watt hours weather those batteries are wired for 12,24,or 48 volts.
    Wire in series for 48 your batteries will thank you and last longer.
      Always opt for higher voltage if you have a choice, and never parallel batteries unless necessary.
      • RatedPG
        • 71
        So when the batteries are connected in series for 48V, you will need a 48V inverter, right?
          • 15125
          Unfortunately yes. Although going with a higher voltage will reduce the need for large wires because the amp draw will also be lower and allow you to use more panel wattage. It will also allow you to build bigger battery systems by using lower voltage batteries (2, 4 & 6v) with higher Ah ratings instead of 12volt batteries with lower Ah ratings.
          Also going with a series wired battery system will allow the charging and discharging to be equal across all the batteries. That increases the chance of all the batteries having alonger life. Wiring in parallel increases the chances of one or more batteries not being equal and dying an early death.
