What wire gauge for 80' run to this 2.52 watt, 0.21 amp, 12v light?
In the first post theres a link to the specs on he light it is led. Looks like a rv 1056 base led bulb. Without driver.Last edited by Ho jo; 06-23-2019, 01:54 PM. -
Is the light an LED with a driver circuit, or a simple resistor current limit, or is it an old school incandescent bulb ?Leave a comment:
Originally posted by Farman View PostSince this light would need constant power, I assume that I would fuse the run directly from this battery to the light. If that's not the correct way to do it, please let me know. The battery tests at 14.6 volts.
Would that simply be 12v? If not, how do I find this voltage?
Yes install a fuse between the battery and load. Size it to protect the wire.Leave a comment:
Originally posted by SunEagle View Post
The calculation depends on what your "source" voltage is...
Originally posted by SunEagle View Post...the minimum voltage needed to run your load
Originally posted by PNPmacnab View PostIs that from the panel to controller or to the light?
Is that from the panel to controller or to the light? I once has a SL something till lightning took it out. Believe it is a PWM controller. Peak power point voltage of panel will be over 17V and the battery could be up to 15V. PWM is like a direct connect. The panel will drop down to whatever the battery is. That means even a 2V loss in the wires makes absolutely no difference. In this case those tables aren't worth a hoot. A 160 feet of #20 is 1.6 ohms and at 0.21A is only a third of a volt. If it is to the lamp from the controller that isn't much of a drop either. I'd be looking at structural integrity of the wire as the deciding factor.Leave a comment:
Originally posted by Farman View PostThanks!
How do you figure this thing? I've used a number of online 'wire gauge calculators', and I've contacted sources for 'expert advice', and I'm getting told everything from 22ga on up to 12ga. Not sure which calculator and/or source to believe.
Thanks again. The input is great.
We can start with 12volt as your source and limit it to say a 2% drop and come up with a wire size but it really depends on what the 2 voltages are in my first statement.Leave a comment:
Thanks!
Thanks again. The input is great.Last edited by Farman; 06-21-2019, 10:18 AM.Leave a comment:
Here's a link to the specs for the light that I'm installing: SL1000
I estimate the run to be somewhere in the 75'-80' length.
Thanks.
