I posted a thread called Re-Wiring my Solar and didn't get a single response other than 37 views. Seemed like all the other topics had responses. My Topic and text was completely Solar and RV related. I would have thought there would be a wealth of info at this site and on this topic. What's up?
About Re-Wiring My Solar
Sorry. I probably skipped by your post.
Going back and looking at it I would say it is hard to give you specific advice on what your RV solar/battery system should look like.
If you had an idea of how many watt hours you will use each day then you can size your battery system. From that data you can then size your panel wattage depending on how they are mounted.
If they are on the ground point to the South you get your best production. If they are flat on the roof and partially shaded you get a poor production.
So how many watt hours do you need and how did you plan on mounting your panels?
