Announcement
No announcement yet.
van solar review help
  • Filter
  • van solar review help
    Hello not sure if my cables are ok , 10 awg for 22 feet ........2 100 watt panels in parrallel
    charge controller.... projecta idc 25 https://www.projecta.com.au/dual-battery-charger-idc25/
  • #3
    • #4
      charge controller specs ...max solar input 23 vdc
      with my setup am i going over 23 vdc ?
      • #5
        Yes, you could go overvoltage in cold weather.
        • #6
          Thanks , im thinking if i wire the panels in series and get a new charge controller . Any suggestions on a charge controller that displays amps from solar panels ?
          I have a 12 volt house battery system in my van .
          • #7
            Please do not make multiple threads on the same topic. It is confusing to the members as to which one to respond to. I may have to close your other threads and keep this one.
            • #8
              sorry for all the posts , i had trouble posting , forum system thought it was spam. Can you keep this post and delete the others i made ?
              i coudnt see where yo delete them
              • #9
                I just closed them so no one could post on them again. That leaves this thread as the only one with your questions.
                • #10
                  Ok my new plan , i will get a new charge controller https://www.amazon.ca/Victron-SmartS...70ZA76CQ8&th=1
                  I will put the 2 100 watt solar panels in series and still use 22 feet of 10 awg , my batteries are 2 105 gel 12 volt in parallel .
                  Should this CC work like this ?
                  • #11
                    the 10 ga wire is "safe" to use, but with the resistance losses, 8ga would be a more efficient choice
