van solar setup help review
  • canuck4everr
    • Nov 2018
    • 14
    Hello wondering if me cables are right size for length , 10 awg at 22 feet ....2 100 watts panels in parrrallel projecta idc 25 charge controller
    panels https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
    panel specs
    cables https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
    charge controller https://www.projecta.com.au/dual-battery-charger-idc25/
    CC specs [TABLE]
    [TR]
    SPECIFICATIONS [/TR]
    [TR]
    [TD="width: 28%, colspan: 1"]PART NO[/TD]
    [TD="colspan: 3"]IDC25[/TD]
    [/TR]
    [TR]
    [TD="colspan: 1"]CHARGE TYPE[/TD]
    [TD="colspan: 3"]3 Stage[/TD]
    [/TR]
    [TR]
    [TD="colspan: 1"]ALTERNATOR INPUT VOLTAGE[/TD]
    [TD="colspan: 3"]9-32Vdc[/TD]
    [/TR]
    [TR]
    [TD="colspan: 1"]MAX SOLAR INPUT[/TD]
    [TD="colspan: 3"]23Vdc, 385W[/TD]
    [/TR]
    [TR]
    [TD="colspan: 1"]OUTPUT CURRENT[/TD]
    [TD="colspan: 3"]Input 9-11Vdc 20A,
    Input 11-32Vdc 25A[/TD]
    [/TR]
    [TR]
    [TD="colspan: 1"]BACK DRAIN ON AUX BATTERY[/TD]
    [TD="colspan: 3"]9.5-10.5mA[/TD]
    [/TR]
    [TR]
    [TD="colspan: 1"]CHARGER CONTROL[/TD]
    [TD="colspan: 3"]Gel: 14.1V,
    AGM: 14.4V
    Wet: 14.7V,
    Calcium: 15.4V[/TD]
    [/TR]
    [TR]
    [TD="colspan: 1"]BATTERY CAPACITY[/TD]
    [TD="colspan: 3"]75-300Ah[/TD]
    [/TR]
    [TR]
    [TD="colspan: 1"]BATTERIES SUPPORTED[/TD]
    [TD="colspan: 3"]Gel, AGM, Wet & Calcium[/TD]
    [/TR]
    [TR]
    [TD="colspan: 1"]SMART ALTERNATOR[/TD]
    [TD="colspan: 3"]
    12V: Turn On: 12.2-20V
    24V: Turn On: 24.4-32V
    Turn Off: <11.9V
    Turn Off: <24V
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 1"]CONVENTIONAL ALTERNATOR[/TD]
    [TD="colspan: 3"]
    12V: Turn On: 13.4-20V
    24V: Turn On: 26.8-32V
    Turn Off: <12.8V
    Turn Off: <25.6V
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 1"]OPERATING TEMPERATURE[/TD]
    [TD="colspan: 3"]-10
    10 ga cable will safely handle 12 A.
      • 15125
      As I mentioned in your other thread I feel that a #10AWG may be too small to keep the voltage drop below 2%. Your system is at 18.9volts and 10.6 amps (2 panels wired in parallel). A #10 Awg can keep the VD at 2% for up to 15 feet distance. You may need bigger wire but it depends on how the CC works with the voltage it gets.
