floating + breaking: would this work?
  • Filter
  • floating + breaking: would this work?
    my system is 50v. I'd like to float it .I'd also like to have an on off switch for the panels and another for the batteries.
    to float it i need to put a fuse on each polarity at both sources, panels and batteries, correct?
    could I combine both functions and connect a double pole breaker with the respective amps at each source?
    would that work or is it a stupid idea?
  • #2
    never mind. even if it would work these things are too expensive.
    I would have deleted the post but I can't figure out how...
    • #3
      No sir, just the batteries. No over current protection is required on the panel circuits unless you have more than 2 parallel strings.
      • #4
        aha. thank you much.
        • #5
          Also don't forget that in many instances, the charge controller needs to see the battery attached first, and the panels last.
          If you do it backwards (panels first, batteries last), the controller, not knowing the difference between a zero-volt battery and no battery at all, may go into a non-efficient safety mode.
          • #6
            yup. thank you! I've seen seen so many warnings about this I don't think I'll ever forget. but I'm making myself a big sign anyway. just in case...
            • #7
              Square D 2 circuit box.JPGSomething like this helps to prevent order of connection problems. Sorry about the fuzzy image.
              • #8
                the sign I have in mind has a lot of explanation points and red letters. maybe a picture of a burning shed. : )
                • #9
                  stupid question I'm sure: what happens when the battery's fuses blow and the controller is left with just the panels connected?
