Sorry I somehow missed this post earlier while I was replying to others. I didn't realize AGM vent at EOL. Is this something that I would be able to anticipate via battery monitoring? I have heard 6V golf cart batteries mentioned many times, but on here I read a sticky I think that basically said, buy lower voltage batteries in the AH rating you are seeking, and string them in series. I don't truly understand why though.
Did I buy the wrong inverter?
Parallel batteries do not share the work evenly. So that is why it's recommended to use low voltage, high amp batteries in series. And it's fewer cells to check !Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
A couple of comments:
They do make chargers that will charge your 24 volt house batteries from a 12 volt source. Victron is one manufacturer.
Sureflo makes a 24 volt RV water pump.
For LED lights, I am tinkering with pairs of 12 volt lights in series to run on 24volts.
Forgive my ignorance, I'm still confused about the advantages/disadvantages of series or parallel wiring in a small system such as mine.
The longest run between a panel and the CC in my case would be 20ft. I originally had been lead to believe the benefit of parallel panel wiring was because it would help to eliminate loses due to partial panel shading.
SunEagle implied (if I understood correctly) that if I went MPPT it didn't matter.
You are saying (I think) that as long as my runs aren't too long, I should go 4P in an attempt to keep the difference between the panel voltage and the system voltage low, except that if I do, I will have the added expense of fuses and/or breakers for each string.
I asked in my previous reply to SunEagle if it would be sufficient to put an 80A breaker on the inverter input, to prevent it from overdrawing on the system. Do you have any recommendations for/against this?
Are AGM batteries safe to have in a vented box inside the bus. My understanding is that FLA are not. Is this correct? Is there any advantage going with 6 2v batteries over 2 6v batteries if the Ah are identical?~AlfComment
As for shading, err shade should not be an issue. Don't park where you have shade when using the system. If you are concerned with shade then put thought into how you orient the panels so at least two will have direct sun. For long term parking and assuming your batteries are fully charged up, so is no real problem as it takes very little power to keep them charged up.
Below is a wiring diagram to get an idea of what you are doing. Pay attention to the bottom drawing as it fits what you are doing using both Inverter and 12 volt DC power.
Example a 12 volt batteries are available from a few AH up to about 200 AH.
6 volts range from around 200 to 900 AH
4 volts from 600 to 1500 AH
2 volts from 1000 up to 10,000 AH for Nuke submarines and telephone offices.Last edited by Sunking; 09-17-2018, 07:30 PM.MSEE, PEComment
This advice comes from Sunking's vast experience and rock solid common sense. Not only will following this advice save you money by building it right and safe the first time, consider the value of this "free" advice. He has a knack for relating some fairly complex descriptions into easily understandable terms.Not taking anything away from all other regular contributors, they all add valuable info here. I just have to say I really admire his ability to convey this info in a straightforward, no BS kind of way..2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Sunking WOW! Thank you for the treasure trove of information. You've given me a ton of digestable directions on how a proper system should be run. Now that I have these design issues figured out, it will probably be a bit of time before I post again as I'm not ready to build yet.
Thank you to everyone else for helping me with this issue. I know I'll be sure to check here first before I buy any more "deals".~AlfComment
The only thing I'd add is that when you get your batteries, you charge them individually first, before putting them into service and wiring in series / parallel or whatever you have.
AGM's are more than happy to gas out if the cells are in an extremely unbalanced state to begin with, which can be common if you just slap them together from the battery outlet and begin to charge.
Re disasters like hurricanes - think carefully about your loads and days of survival. Mainly because the weather is bad for days well after most events like this happen! You may make it through the first initial phase, but then be let down by mother nature for days afterwards. Of course if you can drive away, different story. But maybe you can't and have to shelter in place. That's where external gennys come in handy.
Not much to add beyond what others have said - just be realistic about bad weather. Here in California, recent fires and their smoke plumes can put a big damper on solar as well, so it isn't just wet weather that's a problem. Be prepared to have panels basically doing nothing, with a "plan b".
PNjunction
Thank you for the quick tip on the batteries. That is most definitely a mistake I would have made.
RE: disasters, my family and I rode out Harvey in our home. We are fortunate enough to have purchased in a 50 yr old neighborhood, on a peninsula, next to huge bayou... All of which may sound like a disaster waiting to happen when you get 50+ inches of rain but there is a ton of drainage which saved our butts. The solar system on the bus will be providing mainly amenities that are not essential for survival. Lights, fans, TV, etc... with the expectation that if we did need to evacuate we would do so hopefully a bit more comfortably than those stuck in tiny cars in gridlock traffic. I will be looking into a generator as well as using a battery isolator to recharge the system.~AlfComment
Thank you
~AlfComment
