Newbie to solar and this forum... hello all.
I've been slowly assembling the bits and pieces to solarize my truck camper so as to be able to be off cord for longer before plugging in.
This week I bought 2 new 36 cell poly panels each rated at 160 watts, 22.7 volts Voc, 9.14 amps Isc.
So before drilling the holes in my Bigfoot fiberglass roof and mounting these panels, I want to check that they appear to be working so I could take them back to the local supplier if I have a problem.
The sky has been a bit hazy with forest fire smoke so a totally clear day has not presented itself. Nonetheless using my multimeter, I was able to read a Voc of 21.1 volts around noon. The multimeter on a 10 amp scale at the same time reads around 5. amps and went as high as 7.0 amps. I assume this is the way to measure Isc.
This is all with no battery or charge controller connected, only a multimeter on the output cables from the panel connected directly to my meter.
Next, I cut a piece of opaque cardboard to the same dimensions as 1 cell on the panel, and covered one of the cells. I was expecting a strong decrease in the current reading but that isn't what happened. The current dropped maybe .05 amps out of 5 when the cardboard was used to cover a cell.
More than one cell produced the same drop in current and one produced NO DROP in current when shadowed with the cardboard.
Is this normal for a panel connected only to a multimeter on the 10 amp scale?
Is there something wrong with the panel or the diodes?
I had read that shading one or two cells would really drop the current output of a panel a lot, but it didn't.
( Yes, I know that on my meter you have to plug the probe in to the high amp port to get proper reading. ).
e
Is this panel working normally ? Any knowledgeable help with this would be greatly appreciated. I am stumped.
e
