I have two 100 watt Grape 12/18v panels (GS-STAR-100W) that I was going to mount on my RV, but since I bought them last fall I have decided that I may upgrade to a new coach next year and want to make those panels into a 200 watt portable solution for this summers travels starting in a couple weeks. I am looking for sources for legs, handles, hinges, and cabling to make it quick to setup and take down.
My plan it to install a controller inside the RV Inverter cabinet to piggy back on existing 4/0 cables going to the batteries and wire the input side to a mountable plug if I can find something. I am looking for things like heavy gauge flexible wiring from the panel to a mountable outlet/inlet to plug them into the coach. I want no more than a 2% voltage drop for the cabling. I'm using 18v in the voltage calculation.
I am looking for the below parts
1. Folding legs to stand them up on the long length sides.
2. Corner Protectors
3. 15' cable (10 GA) to connect from MC4 to whatever inlet ports are available for mounting. SAE? (possibly a 30' cable too, 7 or 6 gauge) (12v 12amp )
4. I am thinking that hinges and a handle will not be hard to source, probably HD or Lowes. but if you know something better?
5. I found MC4 connectors to parallel them together from Amazon.
Best Regards, Bill
Best Regards, Bill
