Im living completely off grid in my 35ft keystone 5th wheel in Colorado. Its cold in the winter and hot in the summer.
i mounted 4 x100watt Renogy panels on my roof.
I wired the 4 panels in parallel and fed the wires down the wall into my front compartment to a Renogy 12/24V 30amp PWM charge controller.
I bought 4 100ahr deka intimidator AGM batteries from a guy off Craigslist for $200 total that were 2 years old.i wired these in parallel.
That is pretty much to run my lights and keep the DC on my propane refrigerator on.
Then I bought a MicroSolar 1000watt pure sine wave inverter. And connected it to my batteries. I ran 14/2 romex from the inverter to a breaker I installed on my electrical panel. I just flip the breaker on if I want the inverter, and leave it off when I use the generator. The pain is it only powers half the panel because it is made for a 220v 50amp shire power so half of the panel is one phase and the other half is the other phase.
Over the winter I was somewhere I could plug in. I just went back off grid and my batteries got really low. I want even running the inverter. I feel like I have more power than I possibly need but the batteries drained.
so, I was thinking my batteries might be bad. I charged them up with my generator all day. I took them and got them load tested at batteries plus. They tested good by holding 900amps for 15 seconds. They said they couldn't test the capacity.
so, i hooked the batteries back up but didnt connect the solar to them and hooked up a bayite DC meter to measure how much energy i was using from them. After 24 hours I used 640 watts and the batteries were at 12.4v. So that should be 25% drained. The batteries are 12v x 100ahr x 4 = 4800 watt/hr capacity. So, 25% should be 1200 watts. So, i figure the batteries are at about 50% of their original capacity or 200ahr.
Even at 200ahr, that should be enough batteries for what i need. So, why are they not getting charged up with my system?
I parked under a couple of trees that dont have leaves. Its minimal shade on my solar but definitely shades my camper which really helps keep it from turning into a hot box on sunny days.
my charge controller only gives me Kw reading. When they were connected, it said it generated 1kw. Over one day. It could have been 1.1kw or 1.9kw. I don't which one it is, but I will test it over a couple of days.
But, if I used 650 watts in one day, my 1kw should have more than charged it.
Renogy 100 Watt 12 Volt Polycrystalline Solar Panel | RNG-100P | 4 |
