2 panels 1 controller
  • DanQ
    • Mar 2018
    Hi after some advice, i have a 125w panel on the jayco roof and a 300w portable foldable panel can i run these 2 panels through a single 40amp controller?
    125w specs:
    max power voltage 18.4v
    open circuit voltage 21.9v
    300w specs:
    max power voltage 18v
    open circuit voltage 21.24v
    thanks Daniel
    It looks like it's OK, as long as you are under 40A, the panel voltages match really well for wiring in parallel
    • DanQ
      • Mar 2018
      My main issue is I've heard i possibly need to install blocking diodes in both panels, as in if 1 panel is in the shade and the other in full sun?
        No blocking diodes ever needed with panels made after 1968.
        Delete the word diode from your solar vocabulary, until you are educated enough to be able to break the seal on a panel,and replace a Bypass Diode, and reseal the panel.
          • 5198
          Even a shaded panel will generate up to full open circuit voltage (but little current), so no blocking diode
          is needed to prevent reverse current flow from the unshaded panel. Bruce Roe
